Since the Code doesn't require them to be on their own circuit now, I don't understand the question. The bathroom receptacle and outlets for other equipment within the same bathroom shall be permitted to be supplied in accordance with 210.23(A)(1) and (A)(2). The other equipment may be lights, fan, small heater, etc. as long as they don't exceed 1/2 of the circuit rating. :smile:monkey said:. . . can someone tell me when the code first started requiring the bathroom receps to be on their own circuit?
mdshunk said:I happened to have a 1984 laying here, and there isn't even a "branch circuits required" section in that edition. Now you got me curious. Off to hit the stacks...
ultramegabob said:Code compliant is one thing, and common sense is another, I would pull at least one circuit for bathrooms minimum,
iwire said:I would provide what the customer paid for.![]()
ultramegabob said:Code compliant is one thing, and common sense is another, I would pull at least one circuit for bathrooms minimum, with all the hair dryers, curling irons, curlers, rechargeable toothbrushes, electric shavers, radios, etc. it doesnt take long for them to add up when the wife or teenage daughter is getting ready in the morning....
LawnGuyLandSparky said:![]()
And if you were bidding this job with "one additional circuit, for common sense sake," you would be broke and hungry.
LawnGuyLandSparky said:Those houses were the first planned suburban development in the U.S. Levittown. Of course there are more things to be considered today, but does a modern flat screen LCD television really consume more power than the 18" black & white console TV with TUBES did in the 1950's? If I remember correctly, those puppies threw off some serious heat. Is not a 100 watt lightbulb in a bedroom table lamp still consuming the same 100 watts? (Or perhaps only 14 watts, the CFL equivilant?) I distinctly remember both my grandmother and mother owned blowdriers. They had a metallic chrome case, a cord similar to one you'd find on an iron, and weighed enough to cause serious muscle develpoment in the fairer sex that it came with a table stand.
Changes in code have since required dedicated SABCs, and bathroom receptacles, but aside from those exceptions, there really haven't been any improvements to the residential codes since these houses were wired.
Even a bathroom 20' x 24' doesn't require anything more than what a 5' x 8' bath requires.
The economics are still the same. Even if this were a development of "McMansions" built on spec, if you insist on including circuits and extras that aren't required by code, you aren't going to get the job.
