Hello,
I have a Constant Power Mfg. brand battery charger for batteries in my MCC. Recently, I've observed that the charger's DC amp "jumps" every 4-5 seconds and then repeats. To be exact, the DC amp starts around 1 amp and gradually increases to 1.5 amps, and then suddenly jumps to 6 amps, and then comes back and start doing this again. At the same time, DC voltage stays at 135VDC without changing, however just a very tiny bit of the volt meter "jerk" can be seen as the DC amp jumps.
I have done a visual inspection on the battery bank and no abnormal conditions were found (i.e. liquid level, leaks, bubbles, cracks, etc.), so I'm not sure where to go for the next step troubleshoot. Below are some background info for the system I have.
Batteries:
flooded type, 20 batteries total, (3 cell each, with 2.25VDC nominal cell voltage). Total output voltage: 135VDC.
Charger:
Brand: Constant Power Mfg. (can't find any info on internet)
Input: 120VAC, 29amps
Output: 130VDC, 10amps
Any feedback/comments are welcome. Thanks
Batteries:
Charger:
