This may not be the place to ask this but I thought I would ask it anyway.
If you have a 48 volt ((8) 6volt batteries in series) system for a scizzor lift,do you have to have a 48 volt charger to charge the batteries or will a 12v charger put some charge on the batteries but not as fast? If you parrallel (2) 12v batteries for double capacity will a 12v battery charger still be sufficient to charge the two at the same time or would you have to disconnect them and charge them one at a time?if you have (2) 12v batteries in series for a 24v system do you need a 24v battery charger to do any good?
