I have always taken my batteries to my local mechanic who uses a Snap-On tester. What do you guys use for checking deep cycle batteries for maintenance issues for lighting besides waiting for them to bulge and die? Brand and model is what I am looking for here.
I use batteries for various reasons. UPS, radio field ops, portable lighting, and the usual engine start stuff. Van, car, Harley, lawn tractor.
I use a smart charger to charge them. Internal (not load related) faults are displayed as a fault #.
For flooded SLA's used to start vehicles, I have a load tester (AKA toaster). It is not for use on smaller batteries.
To finish off my elaborate collection, I have a voltmeter and a clock. Any battery in question gets 3 proper charge / discharge cycles followed by a load test (again JUST on car batteries) with the toaster, or a voltage drop watch over 48 hours. Most times a bad battery will show a high self discharge rate.
Are you testing your own with the intent of making them last as long as possible, or are you doing one-shot tests for customers?
If you are testing for customers, they probably want some fancy info, like 'remaining AH' to compare with the initial AH in an attempt to predict a failure date. There are testers that display that info, but it's not of much practical use. Any concernable decrease in AH will induce a symptom detectable with just simple equipment.
