dave_asdf
- tampa florida
i work for a company with a few data centers and had a question for you. in one of our power rooms we have about 96 2.15 volt vlra batteries backing up a 2400 amp, 48 volt DC plant. the manager was complaining about all the breakers supplying the rectifiers tripping when the weather was bad. turns out there was a damper switch on the room's exhaust plenum that would trip the breakers unless there was a pretty good exhaust flow. i came up with a rig that's working fine for now, but the paper plates i'm using as a check valve wont last forever heh. either way do you guys know of any reason a lack of ventilation would trip the rectifier breakers? if anything i think this would increase gassing if it was caused by excessive discharge. i know vlra batteries are susceptible to thermal runaway but i've got no clue how that would link to ventilation, figured that would be a temp sensor around the batteries. you guys think im good to cut the wires going to the rectifier breaker shunt trips?
