In our area of the country many house's are being built with a gas fireplace on the common wall between the master bedroom and master bathroom. The kind with glass faces on both sides. These fireplaces many times have an 120 volt fan motor that you plug into a recpt. inside the base of the fireplace through a hinged door. The fan is also in the base.
1. Is this recpt. considered in the bathroom or the bedroom?
2. GFI protection or AFCI protection?
3. If put on the bathroom GFI (which I think is best), what about the switch by the headboard of the bed to turn the fan on and off.
Any thoughts out there?
