Hi,
I am just starting out in the wonderful field of electrical fun. I have some questions that I can't seem to find the answers to, maybe they are just too simple.
1) The relationship between voltage and current. Is it possible to have more current (10amps) with lower voltage (6 volts). The reason I ask is I have read about the static charge machine that fire huge sparks, extremely high voltage but very low current. The person went onto explain that "either very high voltage with low current, or very high current with low voltage" will create these effects.
2) With a simple 9V battery, why do I get a reading of 9 volts, but not 9 amps when no resistors are in the test.
3) This one goes back to my first question. Bench power supplies - I see different ranges on them, but take one that has a range of 0-30V and 0-10 Amps. Does this mean I could have 1 volt with 10amps?
Thanks for any help, I know they are silly questions, I almost feel I know the answer but am somehow thrown off by the post I read.
Thanks,
-D
Thanks,
-D
