Bell Box
Jimmy7
Boston, MA
Do you need weatherproof wirenuts in a bell box that is mounted outside 2’ above grade. The box has a gasket, so do you need the weatherproof wirenuts? Having some jobsite debate over this one.
LarryFine
Henrico County, VA
Electrical Contractor
I traditionally drill a pair of 1/8" holes in the bottoms of boxes, LBs, etc.
Larger exterior enclosures normally have drain holes from the factory.
Dsg319
West Virginia
Wv Master “lectrician”
Don’t forget the wads of super33 black tape somebody can fight off on a nice warm sticky summer day lol.
Jimmy7
Boston, MA
In this box there will be a 20 amp 125 volt twist lock receptacle in an in-use cover. Does a twist lock receptacle need to be a weather resistant type? This is residential
garbo
Not required but vast majority of poor quality bell boxes that I opened outdoors had water in them. I installed two Killark aluminum FS boxes on the outside of my house almost 50 years ago with quality covers that use four screws to attach them. Still dry & clean inside. The cast iron FS & FD boxes are also great for keeping water out but heavy & expensive. Biggest joke was when bell boxes only used one screw ( middle of duplex receptacle ) to mount flimsy flip cover receptacle to box. Cover would deform and that along with horrible extra thin gasket guaranteed water intrusion.
