mrwalkerhph
Is it o.k. to run the wire for a door chime through a hole in a stud that has 14/2 NMC cable passing through the same hole? Is there a code refernce?
Jim, do they give a Code reference? I don't think there is a prohibition in the code to this type of installation.will get you red tag here. . . . Likely NO but inspectors here will not pass low voltage and romex using same hole.
Thats the nice thing about this forum.all of the Class 2 and Class 3 circuit conductors are in a raceway or in metal-sheathed, metal-clad, non?metallic-sheathed, or Type UF cables.
