ptonsparky
Tom
- EC - retired
What is the typical installation method for belvill washers. Point of contact and another full turn?
Belleville?What is the typical installation method for belvill washers. Point of contact and another full turn?
Enough to load/flex the washer but not so much as to flatten it.
"Exactly halfway between uncompressed and flat." Very quantitative.
That gives you the greatest expansion and contraction range without losing pressure.
Edit time expired, so:Ah, you caught me before the edit![]()
Not that I've read any real technical papers on installation, but don't you have that backwards? Shouldn't it be convex side out, concave side in?PPS: They must always be used in pairs (total = even number) with the concave side out at each end. That way there is no friction at the perimeter to mess up the contact force as the washers compress and expand.
But you lose most if not all the compressive strength of the last washer under the bolt head or nut... unless you have a heavy duty large flat washer(s) between them, which pretty much leads to the pairs should be installed cup to cup....
)()()()( works
You do not exactly lose the compressive strength, you lose the spring travel. And if you use a large flat washer it may just bend anyway and permanently deform.But you lose most if not all the compressive strength of the last washer under the bolt head or nut... unless you have a heavy duty large flat washer(s) between them, which pretty much leads to the pairs should be installed cup to cup.
That's why I said heavy duty... as in beefy enough to not deform.... And if you use a large flat washer it may just bend anyway and permanently deform.
