dmichelstx
- Shreveport, Louisiana, USA
I'm definitely not qualified to do electrical work, and promise to bother you guys no more after this. I'm appealing to your sense of humanity, in hopes that someone here will recognize this is a real situation, I'm a real guy working through a difficult situation, and I'm trying desperately to find the information I need.
I've an urgent need to use a Greenlee 845 bender to bend something called 1.66 MT15 to make ADA Handrails.
Long story short: my partner was a former US Marine, and licensed contractor with a degree in construction. And I'm a damn good salesman. Together we made a great team, right up until he died.
I'm trying to complete the last project we were awarded before his death, which involves installing ADA Handrails on (9) 2-story wooden staircases on a small apartment complex.
Instead of using the Kee-Klamp components we initially recommended, the owner chose instead to save over $2,000 by purchasing pipe from a fence supplier, and having me bend it as needed.
It's called "1.66 MT15", which I think is actually steel tubing (not pipe), and less heavy-duty than the schedule 40 pipe we recommended.
Having never intentionally bent any kind of pipe before, I of course agreed, rented a 500+lb pipe bender, and now cannot get this stuff to bend without creasing.
It basically doesn't bend at all, but instead just folds. The rental company gave me the instructions that came with the Greenlee bender, which I spent most of the day reviewing. At first glance, it seems easy enough, but I've tried both the Rigid and other slots in the shoe for 1-1/2" pipe, as well as both the horizontal and vertical shoe orientations. I'm supporting the pipe. I've tried pushing it faster through the bender, and the opposite.
Nothing is working and I'm now considering panicking as a viable option. I have not yet tried to change the "squeeze" settings, mostly because there's a big label that says I shouldn't have to, before then showing me how to anyway.
Please, if someone who reads this has any experience with this situation, I can't easily describe how meaningful your help would be.
Thanks,
Dan
Thanks,
Dan
