I need to run 30' of wire between an HMI/PLC and a piece of lab equipment. My immediate options are 24VDC and 115VAC. This is well within the capabilities of 24VDC right? The only current through the wires will be enough to activate the coils on relays located inside of the equipment.
I like the 24VDC because its source will be a Class 2 power supply located within the equipment. Is there anything else to consider?
