I have searched the forum and have not come up with a solid answer for my situation so here goes...
I work for a hydraulic systems OEM and we are re-designing the control panel that we use for testing our units. We want to be able to run up to 2 motors between 50 and 100HP each. There is a 200A circuit breaker supplying this panel. What is the best method to allow this? The only guidance I have seen is 430.53(C), however I am not sure that this meets the group installation criteria. Am I correct? Is there another reference? For each of the 2 starters how do they need to be rated if a variable range of motor sizes can be run on each?
