Eddy Current
If you've got 2 ballasts in a light fixture that's flickering?
What kind of ballast? It's not necessarily the ballast's fault that lamps are flickering.
If you have a two lamp magnetic ballast, one bad lamp will cause two lamps to flicker.
If the lamp cathode filaments are not getting power due to bent pins in socket, loose wires, bent chassis, it will also cause problems. If replacement lamps are severely blackening quickly or only on one end, this is the first thing you should check.
