Dr Duke
- North Dakota USA
So this kinda of relates to another post i started asking about HDPE, innderduct is what it's called around here, and rigid metal conduit couplings.
Here in the wet valley of ND I constantly come across water in conduits. This becomes a big problem when winter hits and the temps get COLD. I have had, I think, four calls this winter for broken probes wires and one broken submersible wire at gas stations. Yes you can pull new wire in the spring, but it is a bad deal nonetheless. Managers hate sticking the tanks for deliveries.
This post is asking if I'm dreaming or not. I am imagining using some type of continuous conduit, like "HDPE innerduct" and then changing over to rigid on either end. This continuous run would alleviate any concern for water intrusion, except for the changeover, which can't be much worse than using an "fa" and pvc. I am thinking may very well be faster to install as well. Just pull it off the big reel. Or even some type of flex that could be laid in, in the same fashion.
Is this something within reach, or am I dreaming? Just wanting to find a better more efficient way.
