brantmacga
Señor Member
- Georgia
- Former Child
Working on a house, and I have 3 sets of recessed lights that needed 3-way dimming.
I used this as the master dimmer,
https://www.legrand.us/radiant/products/dimmers/hcl453pmmw.aspx
With this as the companion dimmer,
https://www.legrand.us/radiant/products/dimmers/hmrw.aspx
I’m using Satco LED lamps, and below 70% they just flicker like crazy. Turning another dimmer off/on makes the other lights flicker for a second also. They are listed as LED compatible; their only advice was to try different lamps or a Tru-Universal dimmer.
I’ve tried three different brands of lamp and they all do it. I do have some of the standard Tru-Universal dimmers on single-pole circuits and they work just fine. So I’ve ordered more to replace the Harmony dimmers; the downside is that they are not multi-location dimming capable.
I’ve used the RF tru-universal dimmers with these lamps, as they are multi-location dimmable, but they are 3x the cost as a set.
The WiFi tru-universal dimmers are much cheaper, but I have several RF switches and a hub installed here already, and the WiFi switches are not compatible with the RFLC hub.
Anyway, just a warning that you might want to stay away from these dimmers.
