ivsenroute
- Florida
For those who work in states or jurisdictions that enforce the ICC codes such as the IRC 2006, it is important that you are familiar with those particular books, not just the electrical section.
Common problem with electricians in these areas are notching and boring violations along with placement of lighting sources.
What we often hear as an excuse is: "That is what the prints show so that is all that I did". This is not a good reason but only a poor excuse. The electrician should be more proactive and bring the missing items to the attention of the builder when he/she reviews the prints for his/her bid.
As an example, here is a small section on lighting:
R303.6 Stairway illumination. All interior and exterior stairways
shall be provided with a means to illuminate the stairs,
including the landings and treads. Interior stairways shall be
provided with an artificial light source located in the immediate
vicinity of each landing of the stairway. For interior stairs the
artificial light sources shall be capable of illuminating treads
and landings to levels not less than 1 foot-candle (11 lux) measured
at the center of treads and landings. Exterior stairways
shall be provided with an artificial light source located in the
immediate vicinity of the top landing of the stairway. Exterior
stairways providing access to a basement from the outside
grade level shall be provided with an artificial light source
located in the immediate vicinity of the bottom landing of the
stairway.
Exception: An artificial light source is not required at the
top and bottom landing, provided an artificial light source is
located directly over each stairway section.
R303.6.1 Light activation. Where lighting outlets are
installed in interior stairways, there shall be a wall switch at
each floor level to control the lighting outlet where the stairway
has six or more risers. The illumination of exterior
stairways shall be controlled from inside the dwelling unit.
Exception: Lights that are continuously illuminated or
automatically controlled.
What is your interpretation of this section?
stairway.
