GG
- Ft.Worth, T.X.
Here is the job I lost. I bid $850 which I thought was low but its been a slow week. The other guy got the job for $700 and the HO asked if I would do it for that and I said NO THANKS.
1) Come out of the indoor garage panel with 2-120V 20A circuits that are going to feed an electric fence opener and 4 coach lights 80' from the panel. Along the 80' path you will have to trench you will have to go under a 3' wide sidewalk.
2) One of the circuits you run to the column that the fence opener will be mounted on will feed 4 coach lights that you have to wire up.
3) The 2nd circuit will feed a GFCI recep. with an in use cover plate.
4) Install an empty 1/2 pvc 20' long where the driveway will be poured to be used for the control wiring of the fence.
What would some of you have bid?
[ July 22, 2005, 02:12 PM: Message edited by: GG ]
