codeunderstanding
How do some of you bid on a code commpliance residential building. Perticular old ones more in the late 1800s or early 1900s. This would not be like a bath remodel or a kitchen where you could get a count on items that you know what your going to install and could put a unit price to each item. This would be fixing dangerous wiring.
up dating circuit directory
checking breakers for the right size wires on them
provide bonding around meter
providing grounding conductors to non grounding receptacles and light fixtures
Put knock out seals in un used openings in boxes
tighten loose switches and receptacles
replace non gfi receptacles in bathrooms to gfcis
secure loose and dangling boxes and conduit to walls
putting open air splices into boxes
These are some of the items that would need to be bidded on where the customer does not want a T@M job
