Mike, I would say you don't and won't. How a transformer is built INTERNALLY is like a motor: how it is built internally is not your concern; just use the specs given by the manufacturer for the device.
Googling
bifurcated concentric winding yields discussions that show WHAT it is - although again, I do not think it effects your life using it:
https://books.google.com/books?id=g...epage&q=bifurcated concentric winding&f=false
We see this in high-power broadcast transmitters, using a dual-secondary 3-phase transformer.
The transformer has two complete sets of windings, one set is connected wye, the other delta, forming what is called a '12-phase supply'. so named because there are 12 separate pulses of DC for every 60-Hz cycle.
In order to keep all the voltages as close to equal as possible, the windings are laid down in pairs, 'paired' in winding them so to speak.
See this page, 4th row down, just left of center.
https://www.google.com/search?q=tra...AcQ_AUoAmoVChMI2q68ufyVyQIVxC2ICh2B3w71&dpr=1
hope this helps
Gary
