Re: BIG ORANGE PROBLEMS
OK. I'll add my 2 cents worth to this thread....here are some tips I would suggest when buying from or dealing with HD ( assuming we're all professionals and do electrical work for a living) :
a) If you decide to buy at HD for convenience or any other reason make sure you get there early in the AM. Any other time and you're subject to a thousand homeowners wandering all over the place, long check-out lines and beeping fork lifts.
b) Know EXACTLY what you are going to buy and where it is.......don't rely on advice from sales personnel other than EXACTLY where an item you are interested in is located. You don't need their advice......you're the professional
c) Inspect all items carefully for missing parts. If you are buying goods that are already boxed make sure the box is factory sealed and does not appear to be resealed by a HD employee. Many people buy things and return them a short time later.......check out the "returns" line next time you're there. I once purchased a Bosch hammer drill, used it once, discovered that it didn't do the job I expected and returned it. Lord knows if it wound up back on the shelf or was sent back to Bosch.
d) If you're buying power tools at HD do some research before you buy. Just because it says Milwaukee, DeWalt or Bosch doesn't always mean you're getting the same tool that you would from a tool supply. These tool manufacturing companies mass market many of their items for sale at home centers and will cut corners in many ways such as slightly less power, plastic carrying cases, fewer accessories, etc.
e) If you're hired to do electrical work for a kitchen renovation in a residence where the homeowner bought kitchen cabinets from HD be prepared for a "long haul". You'll probably get a 1-day window to renovate old wiring and install new rough-in work; they (HD) usually don't take out permits for their work - make sure you take out one for yours; there always seems to be a miscalculation on a cabinet or two and the job can't be completed until it's in. This may or may not affect you unless it's the cabinet for the island or peninsula in which case, if you're not there when they decide to install the cabinet, they'll bury the whip you left for the required receptacle.
Bear in mind the cabinet installing contractors on HD's approved list have probably not had a look at the specific project. In many cases the homeowner provided the dimensions and the HD computer worked up the drawings. Everything looks great on paper !!
If you regularly buy from a supply house you'll find that they will work hard to keep your business. If you have a defective product they will not only stand behind you but will find out why it became defective. If you need a rare item they will research and find it for you. You can't really get this service from HD.
Hope this helps !!!
[ January 03, 2004, 08:52 AM: Message edited by: goldstar ]
