Here is an interesting one. A friend of mine is considering buying a large RV that is reported to require 50 ampere service via a power cord with 3 blades and a ground connection. I have reviewed Article 551 and I can not determine if there is a requirement pertaining to how the RV should be wired. Should the RV be wired to accept 120 V from a 50 A source or should it be wired to accept 240 V, 50 A. There is an adapter on the market that is supposed to permit the user to plug into two 30A outlets and then plug in the 50 A RV power cord but, most reports say that the adapter doesn't work (trips breakers, etc). Can anyone shed some light??
