Biomedical Engineering - Amplifier
Paradoxs
New member
Hello, I have a problem!
1- What is application of this circuit? What does it do?
2- Simulate this circuit in a simulator software and by determine correct values for resistors, show heat losses (H) is nearly constant.
3- Calculate H analytically (manually) (voltage division) and compare with part 2 in a software.
Hint:
(Comparator)
4- By proper ratio selection for resistors, show sensitivity of heat losses (H) with respect to thermal resistance (Rt) is almost zero.
We can have a conversation about question 1.
When do you think you might have a temperature sensor that allows you to know the temperature (once calibrated), and the actual thing you can measure is a small resistance that you would need a Wheatstone bridge.
141229-1424 EST
Write the equations for the circuit in your brige circuit. The output voltage is not linear with a change of Rt, but close for small changes.
