Mark Toler
- Mesquite Tx.
- Electrical contractor
Still Blinking Led trims, bulbs. We wired a 2000 Sq.Ft. barn dominium. There was not a uffer installed prior to concrete. The house now has three ground rods 6Ft apart. We have changed out all the recess trims and bulbs, checked all switches and outlets for connection problems none found. Changed out the main and guts at the 200A panel, all grounds and neutrals are good, power company has ran a test to check there transformer it checks out good. We ran the house off of a generator totally off the grid, still blinked. The blinking will jump to other lighting circuits. I put a meter that test magnetic field on the Island. It would spike max about every 10 minutes. My next move is to unplug all devices from any lighting circuit. Remove the dust zapping electronic air cleaner.
