The motor is used to pump air through a 2" hose to aereate a water supply. The motor is single phase 230volts, 6.5 amps with a 250volt standard plug. The rotation was correct, no single phasing, but owner plugged in for 7 minutes connected to a long air hose with nothng attached to it. For moving air I would have thought no need for overloads, but for maimum protection an motor controller would have helped. Since factory 240volt plugs are not to be cut off, do we install an 240volt receptacle with motor controller for an Regenerative Blower motor? Was too long a hose the cause of overheating?..or lack of some backpressure?
