texie
- Fort Collins, Colorado
- Electrician, Contractor, Inspector
Have a 6 unit meter center with main fusible switch class T JJN-400 fuses (Siemans meter pack), each meter/breaker feeder is 100 amp 3 pole Siemans QP (10K). The load on each feeder is minimal (it is not overloaded). I'm told that on 3 occasions over 6 months the same 2 phases/400 amp fuses blow. It seems there is an intermittant phase to phase short. Is it possible that a phase to phase short on one of the feeders could open the 400 amp fuses without opening the 100 amp feeder breaker?
