hotwire62
- Georgetown Ca. USA
one of my customers was running his generator connected through a GE safety switch/ manual transfer switch when utility power came back on one arc fault breaker was damaged, two garage openers , one motion sensor switch and electronics on gas range ,He has used the transfer switch for three years with no problems ,I have the same one on my house and use it all the time in the winter and have had no problems , somehow a surge had to have come through the neutral as the hots are completly disconnected from utility when in generator position how would this happen and would it be wise to put in a seprate knife switch in to disconnect neutral from the utility when gen is running.
