Re: Blueprints?
Celtic is right -- there is no "standard" scale for residential or for commercial or industrial. The scale is whatever the architect or owner chooses to use, trying to make the drawing fit on a page and still be legible.
Look for a scale listed on the drawing, and then double check it to verify it. Sometimes the scale they show is wrong.
If there is no scale listed, look for a room or part of the building that is dimensioned (i.e. from this point to that point is 49'-8").
Use a 3 sided (triangular) architectural scale (ruler) and see which of the 6 scales match that dimension.
Check several places if there are that many dimensioned.
If you know the outside dimension of the building is 50' X 50' -- see what scale on the 3 sided ruler gives you the correct measurement.
Don't get an architectural scale (which reads in scales like 1/4"= 1'-0", 1/8"= 1'-0") mixed up with an engineering scale (also a 3 sided triangular ruler but has scales of 1"=10', 1"=20', 1"=30', etc. Engineering scales are usually used for site plans)
Also, watch out for reduced drawings . These drawings look just like the full size drawings but have been shrunk. Sometimes they are marked "reduced" and sometimes they aren't.
Half size drawings are fairly common in commercial work -- I don't know about residential. But if you bid from a reduced drawing, all of you scaled measurements (conduit, wire, etc.) will be off by the amount of the reduction (unless you compensate for the reduction -- i.e. 1/4"= 1'-0" becomes 1/8"= 1'-0").
I've seen jobs landed that way -- the contractor didn't catch his mistake until it was too late. It's a good way to be very low on a bid.
If you use a scaled ruler on a dimensioned part of the building (on several dimensioned parts if possible) to verify the scale, you can catch reduced drawings even if they aren't marked.
[ April 14, 2005, 02:20 AM: Message edited by: tx2step ]
