Dkimbro
- Clinton, nc
- Installation manager
i hung up my electrical license several years ago , I'm not familiar with boat docks at all. I have a new dock with a boat lift. distance from house to dock boat lift is 130'. boat lift has two motors that I would like to leave at 110VAC. total amp dwg is 24 amps with a ACII controller which needs a single 30 amp ckt. I also want a receptible and light at boat lift. we may want to add another boat lift later on second circuit. this is why i want to pull 220 out there even thought lifts will never be operated at same time. If I'm reading right i need to run #8 THWN . I'm running 4 wires ( black , red, white , and green) in sch 40 PVC from a disconnect at house to boat lift pole where controller is at. my question , confusion, is where to put my GFIC's. i would like to have a non fused disconnect at house for 220VAc 40 amp. put a sub panel at boat lift for 2 -30 amp GFIC's for boat lifts and 1 20 amp gfic for receptible and light.
is this within code and more important is this safe?
thanks,
thanks,
