ryanpickett2003
- Hilliard, FL, Nassau
I have a rebuilt boat lift motor made by Baldor. Its a 1/2 hp, 120-230 volt motor. The switch is a Furnas/Hubbell brand. The wiring diagram is as follows. (230 volts line to 4-5, 3-8-2, 1.) (120 volts line to 4-5-2, 1-3-8) to reverse the motor swap leads 5 & 8. I'm not sure how to make the motor work with the drum switch so it will go up and down from the switch. Thanks.
