Alwayslearningelec
- NJ
- Estimator
When there is a basis of design manufacturer in the spec but also OTHER manufacturers is it more than likely only the basis of design will be able to be used?
Specifying a BOD manufacturer is sometimes the way a crappy MEP firm forces a delegated design on the contractor/subcontractor. If they show manufacturer's part numbers on the details, you should definitely craft your quote around that. You can always RFI for "or equal" or provide an add/deduct alt if you feel you have a better idea.When there is a basis of design manufacturer in the spec but also OTHER manufacturers is it more than likely only the basis of design will be able to be used?
