JRumsey
- Beaumont, Texas, USA
We have recently reviewed our company's bus torque chart and found some of the values are in line with the bolt mfg suggestions (i.e.- 1/4" - 7/16" bolts) but some of the values were much lower than bolt mfg suggestions (i.e.- 1/2" - 3/4" bolts). I started to update our torque chart to match the bolt manufacturers specifications but I have a concern. The torque chart from Fastenal for a 1/2" Grade 8 bolt is 80ft/lbs. If when running main bus in a 480V switchgear I use 1/2" bolts and torque to 80ft/lbs, what happens when the bus bar heats up during use? Theoretically, the bus bar can go as high as 105deg C; have I gone beyond the suggested torque value of the bolt or did the bolt heat up as well and 'give' with the bus?
John
John
