Bolted Connection Resistance
FaradayFF
California
Hello,
Is there a standard or technical resource that provides guidance on what the measured resistance for bolted connection should be?
Thanks,
EE
210426-2203 EDT
FaradayFF:
Think about your question. You need to define what you mean by a "bolt connection".
The material, the force applied, the area of contact, the number of areas of contact, corrosion, and probably other factors will define the joint resistance.
210426-2203 EDT
FaradayFF:
Thanks.
I was thinking along the line of IEEE or NETA standards that would provide published values for what the resistance values would be for bus bar bolted connections, etc..
