Bolting Compression Crimps Together less than 600v
I am working on a project that requires me to splice copper conductors larger that #8 awg by means of high press connections and heat shrink(no split bolts or Polaris taps). My thoughts were to use two connectors bolted together using lock washers. This would allow the conductors to be disconnected if needed instead of irreversible butt splices. Can someone give me some insight to the pros and cons of this? Thanks.
