buddhakii
- Littleton, CO
Hi all. Been awhile since I posted but am having a little confusion on bonding a manual transfer switch. I just want to say thanks for all the good advice and replies. I know this situation will be solved in no time now that I am looking in the right place.
O.k. I have a 1600a 480v service that is back up by a generator. Before it goes to the auto transfer switch it feeds into a section of gear that has two lockout breakers for a roll up gen. So it feeds from the gen., to the mts feeding a 1600a brkr., then to seperate section of gear that contains the service and ats where the neut. is swtched. So if I'm correct I bond the neut. at the gen., but do I also bond at the mts for the roll up gen. I think that should give enough info. If I missed anything I'm sure you all will let me know.
Thanks again guys and gals.
