The Iceman
- Florida
Just when I thought I had grounding and bonding down I came across this: A large sign had a combination 100A meter/panel mounted on the steel column base. In the back of the panel there was a 1" metallic chase nipple going into the steel colmn for the three branch circuits feeding the sign. They also took the # 6 AWG GEC through the same 1" metallic chase nipple, down the inside of the steel column, and to the ground rod.
Is this a violation of 250.64 (E)? I'm thinking this 1" metallic chase nipple should have bond bushings installed for the #6 GEC.
