mrobles
New member
- Stamford, CT
I did a temp 120/240 service with a meter and a main panel under it. They were connected wit a metal nipple. In the meter pan the nipple was in a concentric knock out with a locknut and a plastic bushing. In the panel the nipple was in a threaded hub that was bolted to the top of a rain tight panel. The inspector failed the service because he said I needed a bonding bushing in the meter pan. Am I correct with 250.92(B)2? The nipple will be bonded at the hub end and should not need a bond bushing at the other end.
