I have a 100 amp 208 3 phase 4 wire (3 hot, 1 common) circuit running from the main service panel out to the production floor running a 100 amp 208 3 phase bus duct. The bus duct then runs a 60 amp panel used to operate equipment. I discovered in this 60A panel the ground and the common are bonded together with a bonding bar. The equipment grounds are all essentially connected to the common conductor in the panel. To my knowledge this 60 amp panel is considered a sub panel and sub panels are not to have the grounded conductor and ground bonded together. Is this correct? My plan is to ground the bus tap to the bus using a #10 wire, then run a ground from the tap to the sub panel, Disconnect the bond from the ground bar and common bar, then add a bonding screw from the grounding bar to the panel case. Will this be sufficient ground considering the conduit and building structure are all metal??
