Doc13067
- Bucks County/Philadelphia, PA USA
I have installed quite a few services with main disconnects over the last 18 years. Usually because the load center was too far away for a cable to run through the house without being able to be powered off. I have always run the GEC to the main disconnect and then run a separate ground and neutral inside to the load center and removed the bonding screw. Several times now I have seen situations where they do everything I do in the disconnect but then run SER cable to the load center and run the ground and neutral to the same place and tighten the bonding screw!!! What was the point to run SER and why not just run SEU? The times that I see this the panels have inspection stickers and they are newer construction like maybe from the early 2000s. Does anybody else see this? How could installers that are doing jobs like these not know to separate the ground and neutral? Or am I the idiot and is there some reason that even though there is a main disconnect outside the panel inside should still be considered the main?
