Flex
- poestenkill ny
A lot of the solar installs we do require a large SBJ for the inverter, most often a 250 mcm. Some of the foreman will install the wire in conduit and have to bond it at both ends. They will typically remove the lug from the bond bushing,say an 1-1/2". Then tap the bushing for 1/4" and install a much larger lug then run the 250mcm through the lug which always seems to put a ton of stress on the bushing. Is this a proper install? I didn't think you could alter the bushing like that. If you could use a smaller bond wire with the original lug how would you size it?
