sparkymike
- Alaska
We have multiple Myers hubs installed on a 1/2" steal plate in the floor of a MOD. The floor is two layers with insulation in between. The top part of the floor is removed and a cabinet is mounted above the opening with the area boxed in to create a box for the conductors to run into the bottom of the cabinet. The cable that is connected to the Myers hub is 3/500 MC-HL with ground. The problem is the Myers hub will only except #6 per it's UL listing and the code requires it to be 2/0 because of the service size. Hubbell said the UL listing will be void if anything larger tan #6 is used. The plate that the Myers hub is connected to is bonded with a 4/0 to the service equipment. Where in the code does it help me with the correct size needed for the Myers hub?
