johnheathman
New User
- Kc
- Electrician
I've got a 208/120 volt sub panel fed from a xfrmr fed from a 277/480 volt sub panel that's fed from a service disconnect on a rack of service disconnects on the other side of the parking lot which all share a single #6 from a ground rod to a ground bar that serves the only ground for 4 200 amp service disconnects 1-480 3phase, 3-240 single phase. Since it's on a rack away from the bldg there's no uffer or bldg steel grounds present. Each disconnect has separate neutral and ground going to sub panel in bldg. Also there is a 208/120 volt 3 phase panel inside fed from the 480 volt 3 phase sub panel. Where does the neutral of the 208 volt panel get grounded from?
