thundata
- Los Angeles
- Owner/Builder
I have a situation where the gunite pool sits 27" above grade, flush with raised decking. The bond beam directly butts against the building so there is no way to run a perimeter bond loop 3' from the inside wall and 6" below grade that is typical. What do you do in this situation where the inspector is going to want to see a buried 8-gauge copper loop?
