jmjr55
- Telford, PA
A plumber that I work with was asking me about a gas pipe in his home. He ran a gas pipe through an opening that also has type NM cable going along side of it. He is concerned if there could be a future problem. I felt as long as the NM is in good condition there should be no problem. I also suggested he look to see if his gas pipe is bonded to the electrical system ground. Does anyone have any thoughts on bonding a residential gas pipe to the ground fault path back to the service? What type of fitting should be used? Where in the piping should it get bonded? Thanks for your feed back.
John
John
