kda3310
- Dry Prong, Louisiana
I am wiring up a transformer 480 to 208. When I wire up the bonding jumper do I bring a grounding wire from the 480 panel to connect with my case ground and grounding rod? Will there be one grounding wire from the 480, one going to the 208, one wire from the grounding rod and the bonding jumper going to the X0 all connect to the case ground?
