DaveBowden
- St Petersburg FL
In the 2017 NEC, is there a code section that requires a screened porch built with aluminum framing members to be bonded?
There are receptacles installed in the enclosed area below the screening. The receptacles are in plastic boxes, GFCI protected, and fed with concealed UF cable run thru stud bushings installed in all the holes drilled in the columns. The inspector says the metal framing requires bonding but the only time I remember encountering this is when there was a pool close enough to the framing to merit it and I can't find it in my code book.
