wmabantajr
I'm terminating MC HCF cable in a raceway that isn't permitted to be used as a grounding conductor. All the devices are bonded to a ground screw with a copper conductor and ring terminal listed for CU only. Same for the insulated ground conductor in the MC HCF cable.
What is the permitted method of bonding the aluminum ground conductor in the cable?
Can't find a ring terminal listed for AL. They do have a one-hole aluminum lug I can use. Is that permitted to be used on the ground stud with the ring terminal listed for CU only?
Is there a better way?
