bonding an above ground - all fibergalss pool
khandyside
New member
Outer Banks / NC
hi and thanks for a great forum. I have read many many posts on pool bonding and cannot confirm my application: - i an wiring an all glass - above ground 11 x 22 pool in that it is build up on a 14' platform at deck level here in the outer banks, NC. - i do not see any reason to run a #8 bond wire to or around the pool in that there is no metal associated with the pool, deck, handrails etc. i will bond the the pump, 12v transformer for LV LED lighting, the propane heater, and the water using a Perma-Cast PB2008 Water Bonding Fitting which will be inline at the filter. Have I covered all my bases on this installation? Thanks / keith
Sorry forum rukles will not allow us to help you
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
