LarryFine
- Henrico County, VA
- Electrical Contractor
Good morning.
I'm looking at an existing pool that has had the surround concrete demolished, and will be replaced with travertine tiles on tamped gravel and sand. I found two small pieces of rebar poking out of the center of the shallow end wall, and there is a hydraulic cover operator at the deep end.
What should be done for bonding? I know about needing the mesh under the travertine, as well as any metal such as ladders, and a water bond. The main question is whether I would need to expose existing rebar to connect to like one would for an Ufer ground in an existing footing.
What should be done if I can not find rebar to expose? What might I be missing or forgetting to ask about?
What the pool looks like now, a piece of rebar poking out, and a side wall with no rebar exposed:
![IMG_2189.JPG IMG_2189.JPG](https://forums.mikeholt.com/data/attachments/31/31936-d7aa5208c6940b3931c5b328140f25bd.jpg)
![IMG_2183.JPG IMG_2183.JPG](https://forums.mikeholt.com/data/attachments/31/31937-e0b9750f685f736c10a4fcd591e5c652.jpg)
![IMG_2190.JPG IMG_2190.JPG](https://forums.mikeholt.com/data/attachments/31/31938-f21e7daa0ff145a652781a075a8c01b9.jpg)
