royboy75
- Kernersville NC USA
Is grounding an gas meter as simple as installing a cold waterclamp at gas meter and then running a #6 bare and hitting the system GEC irreversibly?
To help clarify how it makes any difference. Apparently there is no continuity on the inlet and outlet of the gas meter.
Bond on the customer's side of the gas meter. Technically I don't think it requires an irreversible splice because it is not part of the grounding electrode system.
only the grounding electrode conductor requires irreversible splices, this would be a bonding jumper.Bond on the customer's side of the gas meter. Technically I don't think it requires an irreversible splice because it is not part of the grounding electrode system.
